Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Bitlocket
LLLLSSSS
All,
I wanted to ask if anyone ran into an issue with Bitlocker while installing patch 'OS Build 26100.6584'. Basically once installed, on reboot the existing Bitlocker-Key does not work and I am forced to use the Recovery-key, at which point I can reset the pin back to what it was.
Its odd behavior as this has never happened with any of the other Windows patches. I am posting as I am struggling to identify root cause and hoping someone has come across this issue and hopefully was able t identify root cause.
Thank you
Jaime_Lizarme
Hi @LLLLSSSS
Thank you for contacting the Intel Embedded Community. Windows 11 build 26100.6584 (KB5065426) has known BitLocker issues that can lead to recovery key prompts and problems with activation. A major concern with this and other Windows 11 version 24H2 builds is that BitLocker is enabled by default for many users, which has led to widespread data loss for those unaware of the change. If you want to know more about this, please contact Microsoft as, Bitlocker and OS patches, are Microsoft products.
Jaime L.
LLLLSSSS
