Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1397 Discussions
ADL-S / PCH dose not working after SLP_A
doowonjeong
hello
I am using the ALDER LAKE S platform. (PCH: R680E)
NON-DEEP setting and EC is not used.
The power sequence is all fine, and the SPI also operates for about 500 ms after the voltage is applied.
However, currently my board does not work after SLP_A#.
SLP_S5# is not set to 3.3V.
HW STRAP setting of PCH is as follows.
- MAF (GPP_H12 : LOW )
- Disable ESPI ( GPP_C5 : HIGH)
- VCCSPI : 3.3V ( GPP_H18 : LOW )
- BBS ( GPP_I22 : LOW)
CarlosAM_INTEL
Hello, @doowonjeong:
We sent an email to the address related to this account with information that may help you.
@CarlosAM_INTEL.
jlchu0705
Hello,@CarlosAM_INTEL:
I also experienced the same issue.
Could you email me with information about this issue, too?
Thanks!
CarlosAM_INTEL
Hello, @jlchu0705:
@CarlosAM_INTEL.
cc_chen
Thanks!
Diego_INTEL
Hello @cc_chen,
The email is referring to using our IPS support to submit a case regarding this issue.
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
@Diego_INTEL
JackZ
I also experienced the same issue on ALDER LAKE N platform.
Thanks!
Diego_INTEL
Hello @JackZ,
I don't have information about what was mentioned in the email but I it is possible that it was mentioned to use the Intel Premier Support for a better support regarding the issue.
@Diego_INTEL
