hello
I am using the ALDER LAKE S platform. (PCH: R680E)
NON-DEEP setting and EC is not used.
The power sequence is all fine, and the SPI also operates for about 500 ms after the voltage is applied.
However, currently my board does not work after SLP_A#.
SLP_S5# is not set to 3.3V.
HW STRAP setting of PCH is as follows.
- MAF (GPP_H12 : LOW )
- Disable ESPI ( GPP_C5 : HIGH)
- VCCSPI : 3.3V ( GPP_H18 : LOW )
- BBS ( GPP_I22 : LOW)
Hello, @doowonjeong:
We sent an email to the address related to this account with information that may help you.
Hello,@CarlosAM_INTEL:
I also experienced the same issue.
Could you email me with information about this issue, too?
Thanks!
Hello, @jlchu0705:
Thanks!
Hello @cc_chen,
The email is referring to using our IPS support to submit a case regarding this issue.
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
I also experienced the same issue on ALDER LAKE N platform.
Thanks!
Hello @JackZ,
I don't have information about what was mentioned in the email but I it is possible that it was mentioned to use the Intel Premier Support for a better support regarding the issue.
