Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1381 Discussions
Building Crown Beach with BLDK 2.0.0 for Windows
RJoyc
I'm having problems building the Crown Beach (Core Version 1.3.2.16) with the BLDK 2.0.0 install in Windows. I am able to build the Foxbrook code fine. The only instructions I can find for the BLDK Dev App are the Linux setup and start up guides. When I try to build the crown beach I get:
makefile(71) : fatal error U1052: file '$(wildcard features.mak)' not found
So I change the line in the Makefile from
include $(wildcard features.mak)
to
include features.mak
And I get this error:
makefile(75) : fatal error U1034: syntax error : separator missing
Which is line
IMAGE_SIZE=1024
I feel I have some simple setup error since its not even making it through the first few lines of the Makefile. It is possible to do this build in Windows? I only see instuctuions for Fedora and no other discussions about building in Windows.
Richard
FMcNu1
Valued Contributor I
Hello
I believe this should be doable with Windows. Let me make you aware of a support resource you will probably find useful. The Intel® e-Help desk is staffed by Intel representatives who support select Intel embedded platforms including Intel® Atom™ and associated chipsets, and BLDK.
To access e-Help, you need to be a Privileged member of the Intel® Embedded Community. If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
In addition to access to e-Help, Prvileged members may also access the confidential content within the Intel® Embedded Design Center, such as design documents, specifications, and training materials.
Here's where you go in e-Help for BLDK:
http://embedded.communities.intel.com/community/en/intel_e-help_desk/software_support http://embedded.communities.intel.com/community/en/intel_e-help_desk/software_support
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
