Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
DPDK 20.11 compile issue
qlin2000
Trying to build DPDK 20.11. Build with default machine type ("native") works. But, got an error when setting a x86 machine type, e.g.
     meson -Dmachine=silvermont build
The problem seems with compiler setting. File $(DPDK_ROOT)/config/x86/meson.build has code:
# we require SSE4.2 for DPDK
if cc.get_define('__SSE4_2__', args: machine_args) == ''
        message('SSE 4.2 not enabled by default, explicitly enabling')
        machine_args += '-msse4'
endif
The error is: "Could not get define '__SSE4_2__'   "
How to resolve this issue?  What have I missed? Thanks.
CarlosAM_INTEL
Hello, @qlin2000:
You should address your Data Plane Development Kit (DPDK) consultations as a reference to the channels listed on the following website:
https://www.dpdk.org/contribute/#mailing-lists
@CarlosAM_INTEL.
ZeKay
