Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
DPDK API/library question
TAi
I am currently new to the DPDK library, so my question is a bit basic.
I would like to know if I can use the DPDK ring, mbuf or memory pool APIs as generic libraries. For example, my application has nothing to do with the network but it needs a lockless ring buffer library. Do I need EAL or some specific system settings to make it work? I cannot change some settings like HUGETBL support since I don't have root access.
If yes, some code examples will be greatly appreciated.
CarlosAM_INTEL
Hello, aithr:
The information that may help as a reference is stated at:
http://dpdk.org/doc/api/ http://dpdk.org/doc/api/
http://dpdk.org/doc/api/rte__ring_8h.html http://dpdk.org/doc/api/rte__ring_8h.html
http://dpdk.org/doc/api/rte__mbuf_8h.html http://dpdk.org/doc/api/rte__mbuf_8h.html
http://dpdk.org/doc/api/rte__mempool_8h.html http://dpdk.org/doc/api/rte__mempool_8h.html
It is important to let you know as a reference that your DPDK consultations should be addressed to the channels listed at the http://dpdk.org/ml DPDK Mailing List website.
We hope that this information may help you.
Carlos_A.
