Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1417 Discussions
Enabling Boot Guard for Slim Bootloader
tallu
Hi
I'm trying to enable Boot-Guard with SBL.
I'm using Up-Xtreme-i11 board which has Tiger Lake-UP3.
I'm working on Ubuntu 18.04.
I've followed the instruction on document #646640 however I get the following error from fit:
Loading XML file: /home/user/Temp/updated.xml
fit: ../code/util/fitfileio.cpp:88: readFile: Assertion `buffer != NULL' failed.
Error in running process:
./Fit/fit -b -o Temp/Ifwi.bin -f /home/user/Temp/updated.xml -s /home/user/Temp -w /home/user/Temp -d /home/user/Temp
How can I check what is causing the error?
Tal
Jaime_Lizarme
Hi Tallu,
Thank you for contacting the Intel Embedded Community.
Just a note to let you know that we will be contacting you to your registered email.
Jaime L.
