Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1404 Discussions
How to build module iasImage from bzImage outside yocto
FCama1
after making the kernel outside Yocto with a toolchain (generated by yocto with meta-toolchain) is it possible to use the bzImage kernel to boot from mmcblk0p2 instead of iasImage?
Since if I place it inside /boot/ on rootfs it is not used. In yocto once i rebuild the kernel (linux-apl) the process generates not only bzImage but also a new iasImage set.
Is there an other way of building the iasImage module from bzImage?
Francesco
CarlosAM_INTEL
Hello, fcamarda:
In order to help you as a reference please address this consultation to the channels listed at the https://www.yoctoproject.org/tools-resources/community/mailing-lists Yocto Project Mailing Lists website.
We hope that this information may help you.
Carlos_A.
FCama1
Hello Carlos_A,
in yocto mailing list there is not a specific session for meta-ias-xxx but only meta-intel may I submit my question there?
Francesco
CarlosAM_INTEL
Hello, fcamarda:
Thanks for your update.
We would like to have the information that may help you but the website provided as a reference is a third party one, so we suggest contact them to find the information that can help you.
We hope that this information is useful to you.
Carlos_A.
