Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1327 Discussions
How to change DDR DQ Drive Strength?
kwmst
I'm designing a board with a configuration of Alder Lake P(7305E) + DDR4 (Onboard).
SI Result is no problem, and RMT Result is ALL Pass.
However, when I measured the waveform of the DDR I/F, the DQ slew rate during Write operation became Fail. It was 12V/ns against the spec 9V/ns (Max).
I need to weaken the Drive Strength to meet the JEDEC spec, but I don't know how.
Questions
1. Is it possible to check the Drive Strength (CPU Ron) from the MRC log?
2. Is there a way to manually change the Drive Strength?
3. Will Intel support me if I need to modify the MRC source code?
4. Is there documentation about MRC? I want to check the settings and training item and algorithm.
CarlosAM_INTEL
Hello, @kwmst:
We sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
