Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
How to configure Linux SPI driver mcp251x?
MSchu26
I use an Intel Atom processor E3930 with CAN controller MCP2515 with SPI interface. In the Linux kernel there is a driver "drivers/net/can/spi/mcp251x.c".
I am only famiiliar with Linux device tree. But there is no device tree on the Intel Atom platform. Hence my question:
How to configure the mcp251x Linux driver on an Intel Atom platform?
Every hint is gratefully accepted.
With kind regards
Mario
CarlosAM_INTEL
Hello, Mario1:
Based on your previous communication, could you please clarify if the project related to your question has been manufactured by you or by a third-party company? In case that it is a third-party device, could you please give us the part number, model, and where to find its documentation?
Thanks in advance for your cooperation.
Carlos_A.
MSchu26
Thanks for the quick response.
I use the SMARC-sXAL (E2) SMARC 2.0 module https://www.kontron.de/products/boards-and-standard-form-factors/smarc/smarc-sxal-e2-.html https://www.kontron.de/products/boards-and-standard-form-factors/smarc/smarc-sxal-e2-.html with the SMARC Evaluation Carrier 2.0 evaluation system https://www.kontron.de/products/boards-and-standard-form-factors/smarc/smarc-evaluation-carrier-2.0.html https://www.kontron.de/products/boards-and-standard-form-factors/smarc/smarc-evaluation-carrier-2.0.html.
# cat /proc/cpuinfo | grep "model name" | head -1
model name : Intel(R) Atom(TM) Processor E3930 @ 1.30GHz
Do you need more information about the hardware?
The operating system is Linux with kernel 4.12.14.
The mcp251x driver can be loaded
# modprobe mcp251x
but nothing happens.
How can I tell the mcp251x driver which SPI pins and chip select pin to use?
Mario
CarlosAM_INTEL
Hello, Mario1:
Thanks for your reply.
We suggest you as a reference review the information stated at the following website, please address your consultations related to the cited driver to the emails listed there:
https://elixir.bootlin.com/linux/v3.6/source/drivers/net/can/mcp251x.c https://elixir.bootlin.com/linux/v3.6/source/drivers/net/can/mcp251x.c
We hope that this information may help you.
Carlos_A.
