Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
Howto use DCI debugging on the MRB development board
KEise
I'm using a MRB board with the gordon_peak-userdbg Android lunchtarget. I saw that there is a DCI_DEBUG option in the ABL feature csv.
Is there documentation available on howto use DCI? Which USB cable to use, which Host software etc. ?
CarlosAM_INTEL
Hello, konradeisele:
In order to be on the same page, could you please let us know if the design related to your request has been developed by you or a third-party company? In case that it is a third-party design, could you please let us know all the information related to it?
By the way, you mentioned that the "DCI_DEBUG option in the ABL feature csv", could you please give us a detailed explanation of this?
Waiting for the information that should answer these questions.
Carlos_A.
KEise
  • The MRB is Intels Modular Reference Board, the default reference board for automativ Broxton.
  • ABL is the Automative BootLoader
  • DCI_DEBUG is an option when customizing the Automative Bootloader (ABL)
  • I'm running Intels Android AOSP
KEise
Hi, Sorry but it seems you didnt understand the question:
The question is about DCI (Direct Connect Interface(Jtag over USB)).
Please dont try to answer a question that you dont understand :-)
CarlosAM_INTEL
Thanks for your clarification.
The information that may help you is stated at the following websites as a reference:
https://software.intel.com/en-us/articles/system-debugging-via-direct-connect-interfacedci-of-intel-system-debug Debug Intel® ATOM™ platform via Direct Connect Interface | Intel® Software
https://software.intel.com/sites/default/files/managed/73/c2/pdf.pdf https://software.intel.com/sites/default/files/managed/73/c2/pdf.pdf
Also, please review as reference the information stated at:
http://www2.lauterbach.com/pdf/dci_intel_user.pdf http://www2.lauterbach.com/pdf/dci_intel_user.pdf
We hope that this information may help you.
Carlos_A.
KEise
Thanks, that's the first link that you get when googling :-) However not helpful.
CarlosAM_INTEL
Thanks for your reply.
Based on your previous message, as you may notice most of the documents and references related to this topic are related to software developer focus.
These are the reasons to suggest you on my previous message to address your consultations to the forum focused on this kind of topic.
In case that you need it, this channel can be found at:
https://software.intel.com/en-us/Forum https://software.intel.com/en-us/Forum
Carlos_A.
