Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
I2C control by MMIO
AmyChen
I'm using I2C with ADL-S to control the device. Currently, I'm familiar with using SMBus for control. For instance, if I want to control a device at address 0x40 and write FF to register location 0x12, I would perform the following steps in the SMBus registers:
  • IO space+00 = FE (clearing the register)
  • IO space+04 = 40 (device address)
  • IO space+03 = 12 (register address to write to)
  • IO space+05 = FF (data to write)
  • IO space+02 = 48 (write method: byte write)
By following these steps, I can achieve the write operation.
If I want to switch to I2C via MMIO, I've found the base address (memory address).
But what are the corresponding registers, values ​​or steps?
Can you give me a simple example?
Or do you have relevant information to provide me?
Thank you.
CarlosAM_INTEL
Hello, @AmyChen:
We sent an email to the address related to this account with information that may help you to solve this situation.
@CarlosAM_INTEL.
EdwinJr
Sorry to bother you.
I also have the same problem, could you please send me the information on how to solve this situation too?
Thank you for your time.
Diego_INTEL
Hello @EdwinJr,
I think the email refers to make the consultation using Premier Support.
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
You may check:
Document #621483 - PCH EDS Vol 2 for Alder Lake S on section "13 - I2C Interface (D21:F0-F3, D25:F0-F1"
Document #619362 - PCH EDS Vol 1 for Alder Lake S on section "18.0 Intel® Serial I/O Inter-Integrated Circuit (I2C) Controllers"
As a guide or examples I have not found any in our resources unfortunately.
@Diego_INTEL
