Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
Integrating IP core units with Intel® EP80579
KAly
Hello
Can anyone advise the eligibility requirements to work with Intel Embedded team to integrate own IP core units for a specific SoC solution?
Does the procedure need to begin with joining as an Embedded Alliance member? Or could this be discussed with design team directly.
ka
FMcNu1
Valued Contributor I
Hi ka:
Welcome to the Intel® Embedded Community.
In order to give you some guidance here, can you please say a little more about what model you have in mind? For example, do you have some IP that you wish to license to Intel that would be integrated on a part that Intel markets? Or are you thinking of combining Intel IP with yours to create a SoC that you will market?
Felix
J. Felix McNulty
Community Moderator
(Intel contractor)
KAly
Hi Felix
Yes, we are interested in the licensing model, to integrate a set of novel IP core units of much elevance to HPC and acceleration, and take advantage of the lower latency DMA and IO access. In a way, similar to the Intel embedded security appliance that was published in an Intel's white paper.
If you I could discuss detail with you, I'd appreciate if you might advise me how to contact you in person. I'd otherwise appreciate the information about the procedure to qualify a proposal and discuss detail and your referral to the right Intel contact to progress this with.
Thanks & regards,
Khaled
