Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1418 Discussions
Intel 7th gen support with Linux iHD driver.
PKnop
I recently learned that the i7/i5/i3-7th gen CPUs aren't supported on Linux using the iHD driver. This is unfortunate.
There are two drivers to use QuickSync on Linux. iHD (closed source) and i9n5 (open source). i9n5 works on a wide array of platforms, iHD is more limited (7th gen not supported).
iHD offers a lot more throughput, which is ideal for my embedded product that encodes 4K video. I'd really like to use the powerful GPU that the 7th gen has.
https://software.intel.com/en-us/forums/intel-media-sdk/topic/735307 Kabylake support in Intel Media products
"Media Server Studio is not moving support forward to Kabylake architecture (7th Generation Core, Intel® Xeon® E3-1200 v6)."
I urge you to reconsider!
PS: I have ran the iHD on 7th gen, and it works, but there is encoding artifacts. https://github.com/01org/gstreamer-media-SDK/files/1347241/video.mp4.zip See video here. Just fix the artifacts, and I will be good
CarlosAM_INTEL
Hello, pauldotknopf:
In order to give you the information that may help you, could you please give me the part number of the Intel devices related to this thread?
We really appreciate your cooperation.
Carlos_A.
PKnop
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 158
model name : Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
stepping : 9
microcode : 0x42
cpu MHz : 800.000
cache size : 8192 KB
physical id : 0
siblings : 8
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch ida arat epb pln pts dtherm hwp hwp_noitfy hwp_act_window hwp_epp intel_pt tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt xsaveopt xsavec xgetbv1
bugs :
bogomips : 8400.00
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 158
stepping : 9
microcode : 0x42
cpu MHz : 800.000
physical id : 0
siblings : 8
core id : 1
cpu cores : 4
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 8400.00
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 158
stepping : 9
microcode : 0x42
cpu MHz : 800.000
physical id : 0
siblings : 8
core id : 2
cpu cores : 4
apicid : 4
initial apicid : 4
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 8400.00
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 158
stepping : 9
microcode : 0x42
cpu MHz : 800.000
physical id : 0
siblings : 8
core id : 3
cpu cores : 4
apicid : 6
initial apicid : 6
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 8400.00
clflush size : 64
power management:
processor : 4
cpu family : 6
model : 158
stepping : 9
microcode : 0x42
cpu MHz : 800.000
physical id : 0
siblings : 8
core id : 0
cpu cores : 4
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 8400.00
clflush size : 64
power management:
processor : 5
cpu family : 6
model : 158
stepping : 9
microcode : 0x42
cpu MHz : 800.000
physical id : 0
siblings : 8
core id : 1
cpu cores : 4
apicid : 3
initial apicid : 3
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch ida arat epb pln pts dtherm hwp hwp_noitfy hwp_act_window hwp_epp intel_pt tpr_shadow vnmi flexpriority ept vpid fsgsbase ts...
CarlosAM_INTEL
Thanks for your clarification.
It is important to let you know that your consultations related to the https://ark.intel.com/products/97129/Intel-Core-i7-7700K-Processor-8M-Cache-up-to-4_50-GHz Intel(R) Core(TM) i7-7700K Processor should be addressed to the https://communities.intel.com/community/tech/processors Intel Processors Forum because it is out of the Intel Embedded products.
We hope that this information may help you.
Carlos_A.
PKnop
