Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Intel Driver Update Not Working
MichaelPerone
I get this error when trying to use Intel Driver Updater
Diego_INTEL
Hello @MichaelPerone,
I checked it and is working fine to me. You can try to open the tool as administrator or download it again.
@Diego_INTEL
MichaelPerone
No, neither of those ideas work... This is a real issue with the tool
Diego_INTEL
What is the processor that you are using?
Does the tool worked before?
@Diego_INTEL
MichaelPerone
It's an I5. I think I have to go check yes it was working fine. Had the little green dot when it didn't need an update and then the red. When it did now that icon in the task bar has no. And when you click on it it goes to browser that says reinstall. I've reinstalled and repaired. I booted in safe mode. I've done everything and the PC that it's on has all the Microsoft updates. I've done the scans on the PC and even done the verifications on the PC and everything's fine with the PC
Diego_INTEL
I found a workaround that may worth a try. Can you try the tool using Firefox, to check how it goes in this case.
@Diego_INTEL
