Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
Intel Embedded Server cannot discover sata device
jxie9
I am working on Intel Embedded Server, but in boot selection mode, I cannot see the disk inserted in the slot, but the diagnostic message shows the two disk I inserted, and I am sure the two disks are Ok, because they work well on another server.
Please someone help me with this problem, greatly appericate.
boot selection mode
diagnostic message
Natalie_Z_Intel
Welcome back, jiexie! We are looking into your question and will get back with you soon. Lynn
WILLIAM_C_Intel
Hi Jiexie,
I am very happy to assist you with this case.
Could you please tell me what products and embedded platform are you using?
And want to install which operate system?
Thanks~
William
jxie9
I use http://www.intel.com/content/www/us/en/server-systems/server-board-s2600gz-gl-systems.html Intel® Server System R2308GL4GS,
Now I am trying to install RedHat 6.4 OS, but system can't discover the SATA device inserted in the slot, I try all 8 slots with 2 Hard disks which work well on other server.
you can see from the two pics I pasted, in boot selection mode, no Hard drive display, but display in diagnostic message .
WILLIAM_C_Intel
Hi Jiexie,
According to your description, I have some questions not clear, could you please help me to confirm it?
1. Confirm your server board is no problem.
2. In BIOS setup, could you find the two disks?
And you could update your BIOS to try again.
William
jxie9
In BIOS setup, cannot find the two disks.
but why diagnostic message can show the two disk?
jxie9
Platform ID: S2600GL
BIOS Version: SE5C600.86B.01.02.0005
BUILD DATE: 03/21/2012 11:00:48
WILLIAM_C_Intel
Hi Jiexie,
How many server boards do you have? Have you tried to replace a new board?
We should rule the quality problem out at first.
William
