Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1417 Discussions
Looking for old Embedded Microcontroller Development Documentation
WWill10
I am hoping to find some old geezers that might have a copy of "Embedded Microcontrollers & Processors Handbook" Intel Order # 270645
and "16 Bit Embedded Microcontrollers Handbook Intel Order # 270640. I and currently working a project on an MCS96 based 80C196KD model microcontroller. I have the User's Guide which is informational but I still need some insight from an Embedded Controller Developer to get me off the starting line. For example, when do I use vertical-window scheme, when do I not use it. Do the hardware engineers tell me where to read and write memory? How do I determine the best usage of internal memory, external memory? When would I use one or the other? As I am programming do I need the controller schematic to understand the pins, interrupts, etc? How do I write a program to download the *.hex file in to OTOProm etc, etc, etc...
Sincerely,
williawh
FMcNu1
Valued Contributor I
Hi Williamh
Welcome to the Intel® Embedded Community.
I see that it's been a couple days since your post and no "old geezers" have come to your rescue. This might be overly simple, but have you tried to google the title of that manual? I know there's a bunch of websites out there that store old archvied manuals, specs, datasheets, etc. Some are free and others charge a nominal fee. Below are a few examples. Maybe these are docs you already have but I thought it might be worth taking a shot if you haven't already.
http://html.alldatasheet.com/html-pdf/66138/INTEL/8XC196KD20/2675/20/8XC196KD20.html http://html.alldatasheet.com/html-pdf/66138/INTEL/8XC196KD20/2675/20/8XC196KD20.html
http://download.siliconexpert.com/pdfs/2009/5/31/23/35/22/562/re_/manual/int_80c196kc.pdf http://download.siliconexpert.com/pdfs/2009/5/31/23/35/22/562/re_/manual/int_80c196kc.pdf
http://www.datasheets.org.uk/intel+HANDBOOK-datasheet.html http://www.datasheets.org.uk/intel+HANDBOOK-datasheet.html
I hope this helps.
Good Luck!
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
