Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
MCS96 question
Scabben
Hi, I'm upgrading a vintage synthesizer and need to swap the processor. Currently there is a N80C196KB12 and I want to swap it for a N80C196KB16 with a FPO ending with "G". I managed to get a chip with a FPO ending with a "U". Is that likely to work ? I have not found any info on Internet regarding that. The chip is marked '86  '91 so it seems to be a quite late chip ?
thanks / Scabben
Diego_INTEL
Hello @Scabben,
Yes, they are quite old, I don't have any information from this side regarding those processors.
I'm thinking that those letters could be attached to the stepping.
REVISION HISTORY
This data sheet (270909-006) is valid for devices with an ‘‘E’’, ‘‘F’’ or ‘‘G’’ at the end of the top side tracking number. Data sheets are changed as new device information becomes available.
https://www.datasheets360.com/pdf/7922264210598473
Here U is not mentioned.
You may try making a search with the label information to check if there is any result.
https://qdms.intel.com/Portal/SearchPCNDataBase.aspx
@Diego_INTEL
