Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
MDDS for i5-13500TE
SHime
Hello, can you able to help provide MDDS for i5-13500TE, CM8071505109603S RMFZ?
Thank you.
Jocelyn_Intel
Hello, @SHime
Thank you for posting on the Intel® communities. I will do my best to assist you here.
I will proceed to do some research. As soon as I have updates, I will post them here.
Jocelyn M.
Jocelyn_Intel
Hello, @SHime
Thank you for your time.
We have a forum for those specific products and questions, so we are moving it to the Embedded Intel® Core™ Processors Forum so the proper team can help you with your inquiry.
Jocelyn M.
Diego_INTEL
Hello @SHime,
To access MDDS documents you may check the following tutorial.
https://www.intel.com/content/www/us/en/support/articles/000059788/services/quality-regulatory-ecology.html?wapkw=mdds
Regarding the i5-13500TE, you may check the document #769115 - Intel® Core™ i5-13400EF, i5-13400TEF, i5-13500E, i5-13500TE Processor
https://www.intel.com/content/www/us/en/secure/content-details/769115/intel-core-i5-13400ef-i5-13400tef-i5-13500e-i5-13500te-processor.html?DocID=769115
@Diego_INTEL
vigoyu
Hi Diego_INTEL,
I am looking for the MDDS document for i5-13500TE.
The webpage you provided on 6-27-2023 is no longer available.
It shows "Page not found... The page you requested has moved or doesn't exist."
Please support. Thanks.
CarlosAM_INTEL
Hello, @vigoyu:
You need to report this situation by filling out the form stated in the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
Please use the URL option in the Inquiry Type scroll-down menu of the cited form.
@CarlosAM_INTEL.
vigoyu
Hi Carlos,
The MDDS documents are open to download here and there are more than 5000 MDDS "results". I have searched a total of 41 different CPU models for an industrial PC manufacturer we serve. The i5-13500TE was the only model that failed while the other 40 models were found.
https://www.intel.com/content/www/us/en/collections/content-type/mdds.html
By searching "i5-13500TE", the result doesn't include the one for i5-13500TE. The 2nd MDDS document is applied for i5-13500, i5-13500T but without i5-13500TE.
https://www.intel.com/content/www/us/en/collections/content-type/mdds.html?q=i5-13500te&s=Relevancy
CarlosAM_INTEL
Hello, @vigoyu:
Thanks for your reply.
However, we want to address the following consultation to understand the situation:
Where do you acquire the Intel® Core™ i5-13500TE Processors related to your request?
We are waiting for your answer.
@CarlosAM_INTEL.
vigoyu
Hi Carlos,
We ordered i5-13500TE from Sertek, one of your distributors in Taiwan.
BTW, we are serving 90+% IPC OEMs in Taiwan.
CarlosAM_INTEL
Hello, @vigoyu:
Thanks for your update.
We suggest contacting the cited Intel Authorized Distributor to address your request.
They will be more than glad to help you.
@CarlosAM_INTEL.
Diego_INTEL
Hello @vigoyu,
I have been checking and this document has been modified recently, I think there is the same document but with a name change (this is the mistake), because in the title it is mentioned 78785 while in the document it is mentioned "Doc Id 78786".
https://www.intel.com/content/www/us/en/content-details/769115/intel-core-i5-13400e-i7-13700e-i7-13700te-i9-13900e-i9-13900te-processor-78785-mdds.html?DocID=769115
There is an address, "productecology@intel.com", you may try contacting them to confirm if they have the correct document for the i5-13500TE.
@Diego_INTEL
