Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1400 Discussions
PCI serial port Windows embedded standard 7 driver
SSell
I have an Intel Atom Z510 with US15WPT chipset. I have successfully installed a Windows 7 embedded standard 7 operating system but the UPS with a serial port on the PCI bus is not recognized properly. The PCI serial port and PCI serial come up in the device manager but both with exclamation marks. I haven't been able to find a driver that works to recognize these ports.
Any help with getting the correct driver greatly appreciated.
FMcNu1
Valued Contributor I
I want to make you aware of a special place to go with questions like yours. The Intel® e-Help desk is staffed by Intel representatives who support select Intel embedded platforms including Intel Atom™ and associated chipsets including US15W.
To access e-Help, you need to be a Privileged member of the Intel® Embedded Community.
If you are already a Priveleged member, I suggest you post your question here:
/community/en/intel_e-help_desk/software_support http://embedded.communities.intel.com/community/en/intel_e-help_desk/software_support
If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
In addition to access to e-Help, Prvileged members may also access the confidential content within the Intel® Embedded Design Center, such as design documents, specifications, and training materials.
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
