Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Part query
ns
Good day to you!
Can you please let me know the validity (ACTIVE/DISCONTINUED) of below part number.
If part is valid then please provide us the supported datasheet.
Part:
999V0X
999V16
99A40V
99AD8T
99AD8V
99AD8W
99A57N
99AGG8
CarlosAM_INTEL
Hello, @ns :
Thank you for contacting Intel Embedded Community:
The 99A57N is related to the Intel® Ethernet Controller I225-LM, specifically to the Spec Code SLNNH. You can confirm this information in the Ordering and spec information section of the following website:
https://ark.intel.com/content/www/us/en/ark/products/184675/intel-ethernet-controller-i225-lm.html
The 99A57N Product Change Notifications (PCNs) can be found on the following website:
https://qdms.intel.com/Portal/SearchPCNDataBase.aspx?mm=99A57N
The 999V16 is a part number alias used by an Intel Authorized Distributor. You can confirm this information as a reference on the following website:
 https://www.mouser.com/ProductDetail/Intel/JHL8540-S-RH4R?qs=sPbYRqrBIVl%2FESQGvou9MQ%3D%3D
You should verify the availability of the Intel products via our authorized dealers. You should contact the ones located in your geo that better fit your needs. They are listed on the following website:
https://marketplace.intel.com/s/pmp-partner-program/a723b0000008PICAA2/distributor
@CarlosAM_INTEL.
