可能是网卡内的EEPROM 文件不正确或刷写不成功导致。因为在没有网络链接的情况下网卡并没有工作,所以驱动安装是正常的但仍会出现感叹号。
Excuse me? How to write the EEPROM file in the network card and what tools are used?
Hello, @82599Firmwarewritin:
We want to address the following questions to understand the reported situation:
Could you please clarify if the device related to this situation is an adding NIC or LAN card or it is a design using the cited Intel Ethernet Controller?
Could you please let us know the part number, name of the manufacturer, and where to find the information related to the NIC or LAN card or the project related to this situation?
Could you please list the source that you used to develop the design associated with the mentioned Ethernet Controller and if it has been verified by Intel?
We are waiting for your answer to these questions.
Add the firmware of 82599es and use the firmware of accessories. In the system, only three 10g channels appear and one channel is lost. However, in DOS system, four 10g channels can be displayed.Can you provide other 82599es firmware, or know the reason
Thanks for your clarification.
However, we want to address the following questions again:
