Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1399 Discussions
TPM 2.0 - How to enable in INTEL (R) CORE (TM) i7 8700 CPU @3.20GHz
Chiefie
Is Processor INTEL (R) CORE (TM) i7 8700CPU @3.20GHz in Windows 11 compatible with TPM 2.0 in Windows 11 and if so , how can I enable it?
AlHill
Your processor has PTT and is supported by Windows 11:
https://docs.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-intel-processors
It should be enabled.   You can RUN TPM.MSC to verify.   If it is off, or not enabled, look in your bios to turn it on.
[Windows 11 is the new Vista]
Chiefie
Thank you for your advice. I think I have been successful.
Chiefie
Thank you for your information which confirms my PC is suitable to be upgraded to Windows 11
