Is Processor INTEL (R) CORE (TM) i7 8700CPU @3.20GHz in Windows 11 compatible with TPM 2.0 in Windows 11 and if so , how can I enable it?
Your processor has PTT and is supported by Windows 11:
It should be enabled. You can RUN TPM.MSC to verify. If it is off, or not enabled, look in your bios to turn it on.
[Windows 11 is the new Vista]
Thank you for your advice. I think I have been successful.
Thank you for your information which confirms my PC is suitable to be upgraded to Windows 11
