Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1354 Discussions
Unable to assign pins, DDR3, unable to build project, MAX10M50
MOver1
Hello all. I am trying to use the DDR3 memory on the MAX10 FPGA 10M50 Evaluation Kit. In Qsys, I add the DDR3 memory controller. After I "generate HDL" in QSYS, I am told to run a tcl script so that the pins on the FPGA can be assigned to connect with the DDR3 memory on the board. When I try to run this tcl script in Quartus, I receive the following error messages (red text) in the tcl console.
Also, when I try to compile my FPGA design, I see the following outputs in the messages window:
I am prepared to provide any other information about the project should it be needed. I believe I have correctly added the QSYS component.
I have generated the HDL in QSYS without any error messages (4 warnings).
How should I go about solving these issues?
Do I need to provide any additional information so that I can get accurate advice on how to resolve my issues so that I can compile my Quartus project?
Matt
CarlosAM_INTEL
Hello, moverlin:
We suggest you as a reference address your Altera devices consultations to the https://www.alteraforum.com/forum/forum.php Altera Forums because they have the information to proper help you.
We hope that this information is useful.
Carlos_A.
