Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Unable to change values of GPIOs
Suchitra
We are using the Intel Andersenlake yocto build environment for building image for our Intel Xeon processor. Our PCH version is C624 which is used with Xeon processor.
We are using sysfs to read the values of the GPIO pins and we are getting the accurate value at the present time. The issue comes when we want to write into the pin value. The pin value remains same even after changing the value.
Detailed Example:
Step-1: export pin 355 success
              echo 355 > /sys/class/gpio/export
Step-2: set the direction as out also success
              echo "out" > /sys/class/gpio/gpio355/direction
Step-3: change the value from "LOW" (0) to "HIGH" (1) fails without any warning or error
              echo 1 > /sys/class/gpio/gpio355/value
I performed the same steps for reading the values by setting the direction as "in" and able to read the correct value but the issue appeared while writing the value. These pins are connected from PCH to external circuitry.
Is there anything we are missing from the yocto build or our procedure ?
Hardware:
Processor: Intel Xeon
PCH: version C624
Jaime_Lizarme
Hello Suchitra
In order to help you with your Yocto question as a reference please address it to the channels listed at the following website:
https://www.yoctoproject.org/tools-resources/community/mailing-lists https://www.yoctoproject.org/tools-resources/community/mailing-lists
The previous suggestion is based on the following blue highlighted information stated in some of the Intel product brief documents:
We hope that this information may help you.
Jaime L.
Suchitra
Hi Jamie,
Thank you for providing Yocto reference link.
We have posted our query over Yocto community since week ago. Still we are not able to get any response from there.
Any prior help from your side would be much appreciated.
Thank you.
