Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
WIN 11 Compatibility
alewis822tx
I am trying to update to WIn 11 and it says my CPU isn't supported. It is Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz   3.19 GHz. Multiple Cores and higher than 1G so why is it not compatible?
If I have to replace it is there a drop in that is complatible?
Processor            Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz   3.19 GHz
Installed RAM     32.0 GB (31.9 GB usable)
AlHill
That is correct.  Your cpu is not on the list of Microsoft's supported processors for Windows 11.
to replace it, you would have to find an 8th gen or later processor that uses socket LGA1151 and is supported by your motherboards bios.
OR...
You can upgrade now using option 1 in my post:
https://community.intel.com/t5/Mobile-and-Desktop-Processors/Processors-TPM-and-Windows-11-24H2/m-p/1647361#M79106
[AI is the same as snake-oil]
alewis822tx
Thanks for the info!! I verified the TPM was present and used the registry hack... Win 11 up and running!!
n_scott_pearson
To be more specific, Microsoft required that compatible Intel processors have the following:
(I admit, this was blatantly sucked from an AI summary page)
  1. TPM 2.0: This is a security chip that stores cryptographic keys and is essential for features like BitLocker encryption and Windows Hello.
  2. Virtualization-based security (VBS): This feature uses virtualization to isolate security-sensitive processes, making them harder for malware to access. Only Intel's 8th gen and later processors support this feature (and, BTW, for AMD, it was Zen 2 and later processors that supported this feature).
  3. Secure Boot: This ensures the computer starts up using only trusted software, preventing malware from loading during the boot process.
  4. Intel Boot Guard: This feature protects against unauthorized code execution during the boot process.
  5. Hardware-level protections against Spectre and Meltdown: 8th gen processors and newer have hardware-level mitigations for these vulnerabilities, which were prevalent in older processors.
Now, all this said, you can still use Windows 11, albeit without formal support from Microsoft and albeit without the security benefits Microsoft was going for, on processors that didn't have these features. You can follow Doc's instructions for doing this upgrade.
Hope this help,
P.S. I find it frustrating that I couldn't find a good summary of this on the Microsoft site. There may be one there, but I couldn't fint one in my cursory search. Just saying.
AlHill
I do not know how I feel about AI looking so much like Al.<G>
