Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1324 Discussions
What did the host cpu on PCIe read completion abort (ERR_NONFATAL)?
RBran6
Hello to all.
What did the host cpu (Intel-Core-i-Serie) do when a PCIe read completion abort occur (no advanced error reporting is enabled)?
In my imagination: If the host cpu initiates a pci-memory-space-read and if the response was a read completion abort, the root complex translates the completion abort in ERR_NONFATAL. But what did the host cpu in this case? Did an general fault exception or an machine check exception occur?
Thank you.
FMcNu1
Valued Contributor I
Welcome to the Intel® Embedded Community.
I want to make you aware of a special place to go with questions like yours. The Intel® e-Help desk is staffed by Intel representatives who support select Intel embedded platforms including Intel Core™ i series
To access e-Help, you need to be a Privileged member of the Intel® Embedded Community.
If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
In addition to access to e-Help, Prvileged members may also access the confidential content within the Intel® Embedded Design Center, such as design documents, specifications, and training materials.
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
