According to release notes of Bay Trail Gold 004 and MR5 supported BCT version is 3.1.3, but on GitHub last available version seems to be 3.2.0. Where I can get 3.1.3 ?
Also prepared packages are available only for Fedora and binary is build for quite old configuration:
ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=8c06e08e8d7719b17d5161d3bacd369dd13cee0a, with debug_info, not stripped
Why there are no BCT for most widely deployed distribution like Debian ?
Running most recent version 3.3.1 on Debian I get:
# ---- Notes ----#
Please provide additional information about the crash below.
# ---- System Information ----#
Binary Configuration Tool Version: 3.3.1
Operating System: Linux 4.14.0-2-amd64 x86_64
Python Version: 2.7.12 (default, Sep 2 2016, 14:46:00)
[GCC 6.1.1 20160621 (Red Hat 6.1.1-3)]
wxPython Version: 3.0.2.0 gtk3 (classic)
wxPython Info: (__WXGTK__, wxGTK, unicode, gtk3, wx-assertions-on, SWIG-1.3.29)
Python Encoding: Default=ascii File=None
wxPython Encoding: UTF-8
System Architecture: 64bit x86_64
Byte order: little
Frozen: True
# ---- End System Information ----#
# ---- Traceback Info ----#
*** Thu Jan 11 00:41:46 2018 ***
File "", line 605, in
File "", line 601, in startBCT
File "/mnt/hgfs/Fedora24ShareVMP/bct331release/bct/install/fc14/64bit/build/pyi.linux2/bct/out00-PYZ.pyz/core.appmain", line 1375, in main
File "/mnt/hgfs/Fedora24ShareVMP/bct331release/bct/install/fc14/64bit/build/pyi.linux2/bct/out00-PYZ.pyz/core.appmain", line 114, in __init__
File "/mnt/hgfs/Fedora24ShareVMP/bct331release/bct/install/fc14/64bit/build/pyi.linux2/bct/out00-PYZ.pyz/wx._core", line 8628, in __init__
File "/mnt/hgfs/Fedora24ShareVMP/bct331release/bct/install/fc14/64bit/build/pyi.linux2/bct/out00-PYZ.pyz/wx._core", line 8196, in _BootstrapApp
File "/mnt/hgfs/Fedora24ShareVMP/bct331release/bct/install/fc14/64bit/build/pyi.linux2/bct/out00-PYZ.pyz/core.appmain", line 193, in OnInit
File "/mnt/hgfs/Fedora24ShareVMP/bct331release/bct/install/fc14/64bit/build/pyi.linux2/bct/out00-PYZ.pyz/core.licensecheck", line 67, in __init__
AttributeError: 'NoneType' object has no attribute 'SetBitmap'
# ---- End Traceback Info ----#
Open source tool that can be supported after commercial hype pass would be much better choice IMO.
Hello, pietrushnic:
In order to help you, please address these questions by filling out the https://firmware.intel.com/content/support Intel(R) Architecture Firmware Resource Center Support form.
We hope that this information may help you.
Carlos_A.
Hi Carlos_A ,
the same in this case. It looks like your Architecture resources are very busy.
