Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
dpdk+qat
Hi All,
I have some questions about the example application 'dpdk_qat'.
1) what should I see when executing the example?
that means, I can run it, but it just running always unless I stop it manually by typing ctrl+c.
2) According to the doc# 328218-006, the section 18.3.2, it says we can refer to the doc# 450257,
where can i found it?
Thanks a lot !
CarlosAM_INTEL
Hello Leo_Yeh,
The information that may help you is stated in the http://dpdk.org/doc/guides/sample_app_ug/intel_quickassist.html Intel(R) QuickAssist Technology (QAT) Sample Application web site, specifically in sections 22.3.
On the other hand, reviewing the http://www.intel.com/content/dam/www/public/us/en/documents/guides/intel-dpdk-sample-applications-user-guide.pdf Intel(R) Data Plane Development Kit (Intel(R)DPDK) Sample Applications User Guide document # 328218-008, which a newest version than the cited on your previous communication, the document # 450257 is unmentioned.
Please let us know if this information is useful to you.
Carlos A.
Hi Carlos A,
Thanks for reply.
Yes, I just refer to this document /dpdk.org/doc/guides/sample_app_ug/intel_quickassist.html Intel(R) QuickAssist Technology (QAT) Sample Application , and I can build it, I can run it, there is no error occured.
my point is, what is the behavior/output after executing the example ?
Leo,
CarlosAM_INTEL
Hello Leo_Yeh,
Thanks for your reply.
Please refer to the bottom of the provided web site, where is stated details on how it works.
By the way, Could you please tell us if you generate any packets from an external source? Please give us all the details.
Thanks in advance for your help to solve this inconvenience.
Carlos A.
Hi Carlos A,
Thanks for reply.
I will try it, and will update here when available.
Thanks a lot!
Leo,
Hi all,
I mean, when I executing this command './build/dpdk_qat -c 0xff -n 2 -- -p 0x3 --config '(0,0,1),(1,0,2)'
and I get this:
my question is, what then?
it just running always...
I don't understand what is its behavior or output ?
Thanks a lot!
Leo,
CarlosAM_INTEL
Hello Leo_Yeh,
The output is inexistence on the system; the application is running on above what you provided in the screen shot.
The application is waiting to receive Ethernet packets on the Ethernet interfaces and take action depending on the "D" as is stated on the web site mentioned on our previous communications, the "D" values should be the following:
D = 0: the forwarding path is selected (the packet is forwarded out directly)
D = 1: the cryptographic path for encryption is selected (the packet is first encrypted and then forwarded out)
D = 2: the cryptographic path for decryption is selected (the packet is first decrypted and then forwarded out)
Carlos A.
Hi Carlos A,
Thanks for these information.
I will retry it.
Thanks a lot !
Leo,
CarlosAM_INTEL
Hello Leo_Yeh,
We are glad to hear that the provided information could be useful to you.
Please do not hesitate to contact us again if you will have more questions.
Carlos A.
Hi Carlos A,
Let me ensure the topology.
I mean, what is the testing topology or diagram?
Is it like this?
Thanks a lot !
Leo,
CarlosAM_INTEL
Hello Leo_Yeh,
The suggested topology is stated in the Overview section of the http://dpdk.org/doc/guides/sample_app_ug/intel_quickassist.html# figure-quickassist-block-diagram Intel(R) QuickAssist Technology Sample Application. It is the following:
Carlos_A.
Hi Carlos A,
Actually, I don't understand the topology in the overview section.
anyway,
thanks a lot !
Leo,
CarlosAM_INTEL
Hello Leo_Yeh,
Thanks for your update.
You are welcome.
Carlos_A
