Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
eeupdate ARM Tool
vlin10
Hi Intel Team,
Could you please provide us eeupdate ARM tool and the Usage guide.
Please send to mailto:[email protected] [email protected]
Thanks in advance
Best Regards
CarlosAM_INTEL
Hello, vic918:
The https://cdrdv2.intel.com/v1/dl/getContent/348742 Intel(R) Network Connections Tools document # 348742 has the Eeupdate.
It is accessible when you are logged into your Resource & Design Center (RDC) privileged account. It can be requested by filling out the https://www.intel.com/content/www/us/en/forms/design/contact-support.html RDC Account Support form.
We hope that this information may help you.
Carlos_A.
vlin10
Hi Carlos,
In fact I already have this file https://cdrdv2.intel.com/v1/dl/getContent/348742 Intel(R) Network Connections Tools document # 348742, but there is no eeupdateARMTool inside.
Our platform is ARM base, so we cannot use https://cdrdv2.intel.com/v1/dl/getContent/348742 Intel(R) Network Connections Tools document # 348742 to flash MAC address.
Could you please provide us eeupdateARMtool source code ?
Vic
CarlosAM_INTEL
Hello, vic918 :
Thanks for your reply.
In order to help you, we will contact you via email.
Carlos_A.
vlin10
Hi Carlos,
Thanks for your help. I already receive eepromARMtool.
After check document and source code we find eepromARMtool only support flash I211 iNVM.
But we want to flash I211 NVM on ARM platform.
Does any tool can flash I211 NVM on ARM platform?
Vic
CarlosAM_INTEL
Hello, vic918 :
Thanks for your update.
In order to help you, we have sent you an email.
Carlos_A .
vlin10
Hi Carlos,
I do not receive the email that you mention which include some information can help me.
Could you send it to me again?
Vic
CarlosAM_INTEL
Hello, vic918 :
We have sent the email again.
We hope that it can help you.
Carlos_A.
vlin10
Hi Carlos,
Thanks for your help. I already receive eepromARMtool again.
The eepromARMtool only support flash I211 internal NVM.
This is explained in the document # 523420 charter 2.1 Supported Devices.
But we want to a tool which can flash I211 NVM on ARM platform.
Does you know any tool can flash I211 NVM on ARM platform?
Vic
CarlosAM_INTEL
Hello, vic918:
The information that may help you is stated in the answers to the questions 2.9, 2.14, 2.15, and 2.16; on pages 6 and 8 of the https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions [FAQs] document 335346.
Carlos_A.
cqing
Dear Carlos A:
I also need the tool for arm 32. please send emil to me about the source link !
Thank you very much!
Best Regards
Qing
CarlosAM_INTEL
Hello, CH_Qing:
The https://cdrd.intel.com/v1/dl/getcontent/572162 Intel I210, I211, and X550 EEPROM Access Tool (EAT) document # 572162 has the requested information.
This tool is accessible when you are logged into your Resource & Design Center (RDC) privileged account as well.
Carlos_A.
RWu
Hi Carlos,
Thanks in advance
Best Regards
CarlosAM_INTEL
Hello, Aaeon:
Could you please confirm if this request is the same state in the Carlos_A.
DAnde8
was there a resolution to this? i am looking for the eeupdate o r eeprom for AARCH64 (64-bit ARM) as well....
CarlosAM_INTEL
Hello, DavidAnders:
Thank you for contacting Intel Embedded Design Center.
In order to be on the same page, could you please tell us the part number of the Intel device related to your consultation?
By the way, could you please let us know if this question is related to a technical problem?
Waiting for the information that should answer these questions.
Carlos_A.
cqing
Dear Carlos_A.
I used the I210 on my imx6q board.
$ ./EepromAccessTool
Copyright(C) 2017-2018 by Intel(R) Corporation
NIC BUS DEV FUN Silicon Memory Type Present
1 1 0 0 I210 INVM+FLASH
$ ./EepromAccessTool -NIC=1 -f=Dev_Start_I210_Copper_NOMNG_8Mb_A2_3.25_0.03.hex
Intel(R) EEPROM Access Tool NVM/OTP Programming Example Tool Version 0.7.6
Provided under the terms of a CNDA. Do Not Distribute.
size is 100000
Hardware rejected opcode=1000000, addr=0
WriteFlswFlashCommand in WriteNvmFlswI210 failed
Hardware rejected opcode=1000000, addr=2
Hardware rejected opcode=1000000, addr=4
Hardware rejected opcode=1000000, addr=6
$ cat /proc/bus/pci/devices
0000 16c3abcd 13e 1c00000 0 0 0 0 0 1d00000 100000 0 0 0 0 0 10000 pcieport
0100 80861531 13e 1000000 0 1001 1800000 0 0 0 800000 0 20 4000 0 0 0
and the P12 was pull down.
And this is what root cause ? thank you very much!
Best Regards
Qing
CarlosAM_INTEL
Hello, CH_Qing:
Thanks for your replies.
In order to be on the same page, could you please let us know the sources that you have used to develop your design? By the way, could you please let us know if it has been reviewed by Intel?
Waiting for your answer to these questions.
Carlos_A.
cqing
Dear Carlos_A.
I just want to see if the selected image is correct?
my case is :
1. use the I210 internal phy, so use the coper
2. just use the i210 as a normal ethernet, and no other special needs
3. flash is 8Mb
so I selected the image Dev_Start_I210_Copper_NOMNG_8Mb_A2_3.25_0.03.hex in Flash Images/I210/Twisted_pair.
and I used the tool is eepromaccesstool-0-7-6. so the image files is hex format.
Is correct for my case ? thank you very much!
And another question is , If I want to modify the mac address and led blank logic, What I should do ?
Thanks very much!
Best Regards
Qing
cqing
Dear Carlos_A.
Thanks very much ! How can I do for that intel review my design?
Best Regards
Qing
CarlosAM_INTEL
Hello, CH_Qing :
The procedure is stated in the https://edc.intel.com/Tools/Design-Review/Default.aspx?language=en&r=380356071 Design Review Services website.
Carlos_A.
