Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1418 Discussions
intel IO margin tool issues on dual-RJ45 port.
darren_wu
Hello There,
I have an issue with using the IO margin tool to test our system, which will get a failed result.
When I do test PCIE LAN port0can get pass result. Then, change to the PCIE LAN port1 and find the IOMT report fail result. (I had tried to find any error log, but I can't find anything.)
system config:
platform: x6211E
LAN IC: I210*2
CarlosAM_INTEL
Hello, @darren_wu:
We received your request, but we want to address the following questions:
Has the affected design been designed by a third-party developer or by you?
In case it is a third-party device, what is the manufacturer's name and the device's part number?
In case it is your design, has the affected design been verified by Intel?
We are waiting for your answer.
@CarlosAM_INTEL.
