Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
307 Discussions
Coreboot & EDKII setup used for tlaquepaque CRB
Tamilselvan
Can we get access to the Coreboot & EDK-II source code ported on tlaquepaque CRB?
CarlosAM_INTEL
Hello, @Tamilselvan:
You need to address this type of request to channel listed as a reference in the following website:
https://www.coreboot.org/consulting.html
@CarlosAM_INTEL.
Tamilselvan
In our design, Discrete chips of DDR4 will be used instead of DIMMs.
In Binary Configuration Tool, there is no option of configuring DDR4 for discrete chips. I could see only the DIMMs option(RDIMM/UDIMM).
Can we get any reference code to configure the DDR4 for the discrete chips option? Where can i find the DDR4 configuration sequence?
Tamilselvan N
CarlosAM_INTEL
Thanks for your reply.
The Memory Reference Code consultations should be addressed to the BIOS developer. However, you are using Coreboot then your consultations should be addressed to the channel mentioned in our previous communication.
@CarlosAM_INTEL.
Tamilselvan
Hi @Mæcenas_INTEL
Thanks for the reply.
Can we get the BSF used along with FSP in the tlaquepaque CRB?
This will be a great reference to our design.
Tamilselvan N
CarlosAM_INTEL
Your last request should be addressed as a reference to the channel listed in the following website:
https://github.com/intel/FSP/issues
@CarlosAM_INTEL.
