Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
xeon D 1559
Jinto
Please provide
1. Power supply design guidelines/documents for Xeon D 1559
2. Recommended (or validated)DDR4 DIMMs with Xeon D 1559. Buffered or unbuffered DIMM is fine. 16 GB Capacity per  channel with ECC.  Need speed 2400 and dual Rank DIMM
CarlosAM_INTEL
Hello, @Jinto:
You can find the power guidelines in the Voltage Regulator Module (VRM) and Enterprise Voltage Regulator-Down (EVRD) 12.5 Design Guidelines document # 495853 that has information that may help you. You can find it when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/495853.htm
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided site. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
On the other hand,  you may find the memory requested information on the following website:
https://www.intel.com/content/dam/www/public/us/en/documents/platform-memory/ddr4-2133-sodimm-ecc-validation-results.pdf
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @Jinto:
Thanks for your reply.
It means that you should use the latest MRC available.
@CarlosAM_INTEL.
Jinto
Hi
The link provided by you is for Broadwell EP
I am looking for power design guideline of broadwell DE (Xeon D 1599 is the part). Kindly share the relevant data.
CarlosAM_INTEL
Hello, @Jinto:
The cited has been suggested based on the information stated on page 76 of the Broadwell-DE SoC-Based Grangeville Platform Design-In Presentation for IOTG Customers document # 554143. It can be found when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/554143.htm
@CarlosAM_INTEL.
