Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
316 Discussions
Coreboot for IceLake D LCC
AaronChang
I have a board with IceLake D LCC SoC, and I am trying to boot the board with Coreboot.
So below is my questions:
  1. Does Coreboot support IceLake D LCC SoC?
  2. If yes, what is the platform option and where can I get Intel’s FSP for it?
Many thanks.
Max
Jaime_Lizarme
Hello @AaronChang ,
Yes, Ice Lake support Core boot; please refer to the following links to get more information:
https://doc.coreboot.org/soc/intel/icelake/iceLake_coreboot_development.html
https://github.com/intel/FSP
If this for a third-party manufacturer board, you can also get Intel support through your OEM.
Jaime L.
AaronChang
Hi Jaime,
Thank you for the reply. I found that the Coreboot supports IceLake-Y and IceLake-U, but I can’t find IceLake-D.
Do you mean I can use IceLake-Y or IceLake-U option to compile the image for IceLake-D?
Max
Jaime_Lizarme
Hello @AaronChang ,
As Coreboot is an independent Open Source project, is really up to them add support for a given Board/CPU SKU. I was not able to find any reference at Intel side; so I recommend checking with Coreboot at https://www.coreboot.org/ contact us support.
Jaime L.
Ken_L_
Hi Jaime,
Thank you for the recommendation.
BRs,
Max
Rajat_Dongre
Hi Jaime_Lizarme,
   I am using board with Icelake D LCC SOC.
   I am not able to find Icelake folder in soc/intel/ directory of coreboot.
   The link you shared is not opening (server not found 404 error).
   Could help me why it not showing me support for icelake D LCC SOC?
   If coreboot is not supporting it, is there any alternative which will support icelake family (Intel Xeon D-1700 processor)
Thanks & Regard,
Rajat Dongre
CarlosAM_INTEL
Hello, @AaronChang:
We suggest reviewing as a reference the information stated on the following website:
https://review.coreboot.org/q/icelake
In case you have consultations related to Coreboot, you should address them as a reference to the channel stated on the following website:
https://ticket.coreboot.org/
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @Rajat_Dongre:
By the way, we suggest verifying the information stated on the following website that may help you:
https://slimbootloader.github.io/supported-hardware/icdx-crb.html
@CarlosAM_INTEL.
