Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
Device ID of HM570E
Siddhartha
Hi.
I know that the PCI Vendor ID of Intel is 0x8086.
I need to know the PCI Device ID of the HM570E Chipset.
  • Google Gemini tells me the device ID is 0xd136. Is this correct?
Thanks, cheers!
Diego_INTEL
Hello @Siddhartha,
I have that the device ID for the HM570 is 0x438B. I find it in document #615985 - TGL PCH EDS Vol1 in "Table 9. PCH-H Device and Revision ID Table".
And it is mentioned the following: "PCH-H mobile full featured engineering sample : 4382".
Unfortunately I can't find the device ID value for the HM570E that is the one that you are looking for but I think it should be something related to 0x438x.
@Diego_INTEL
Siddhartha
Hi @Diego_INTEL
Ok. Google Gemini gave a horrible answer.
HM570 vs HM570E
Please see the link above (HM570 vs HM570E):
  • Seems like HM570 is Discontinued. So its device ID of 0x438B may not matter so much.
  • But HM570E is Launched:
    • So its device ID probably matters.
    • Can you get a circuit board with the HM570E & check its PCI devices (Device Manager on Windows, lspci on Linux)?
Thanks, cheers!
Diego_INTEL
Hello @Siddhartha,
Just as an update, the boards we have in our lab doesn't have the HM570E, I will consult if I can get one with this PCH.
@Diego_INTEL
Siddhartha
Hi @Diego_INTEL
Ok. Hope you can find a HM570E board without difficulty & get the Device ID.
Thanks, cheers!
