Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
318 Discussions
Integrated Channel Analysis Tool
LU001
我在哪里可以下载 ICAT
CarlosAM_INTEL
Hello, @LU001:
This channel only provided support only in the English language.
In case you need the Integrated Channel Analysis Tool (ICAT) information, you can find it on the following website when you are logged into your premier account:
https://designintools.intel.com/product_p/stlgrn160.htm
@CarlosAM_INTEL.
MarcosFernandez
Hi Carlos,
I'm new to the tool and need start using it however I've been trying to log into it a there's always the following error:
Request Id: e7343479-a666-4a23-bbee-203de7f47400
Correlation Id: 177acd42-3cb9-400c-9dbb-fd104e17e557
Timestamp: 2023-02-22T16:42:52Z
Message: AADSTS90072: User account '[email protected]' from identity provider 'https://sts.windows.net/94525b16-dc90-4dcc-82bc-0719e14b378e/' does not exist in tenant 'Intel Corporation' and cannot access the application 'https://designintools.intel.com/nma/auth/saml2'(Intel Design In Tools Store) in that tenant. The account needs to be added as an external user in the tenant first. Sign out and sign in again with a different Azure Active Directory user account.
I've been trying this for a couple of weeks now but with the Azure implementation apparently even my past basic account was deleted. Where can I find help to be added as an external user and start using the tool?
Thank you,
-Marcos
CarlosAM_INTEL
Hello, @MarcosFernandez:
The suggestions that may help you with the cited problem can be found on the following website:
https://designintools.intel.com/customer-service#login
@CarlosAM_INTEL.
