Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
317 Discussions
Intel Compiler VS GCC for mov operation
NStoj
We have an issue with Intel Compiler when compiling this set of code:
asm volatile(
"mov %%cr4,%%rax\n\t"
"orq $0x406F0,%%rax\n\t"
"mov %%rax,%%cr4\n\t"
"mov %%cr0,%%rax\n\t"
"orq $0x2,%%rax\n\t"
"orq $0x10,%%rax\n\t"
"orq $0x20,%%rax\n\t"
"mov %%rax,%%cr0\n\t"
: : : "rax");
For all mov related operation it will add rex.W prefix.
627a: 48 0f 22 c0     rex.W mov %rax,%cr0
GCC will not do that:
7137: 0f 22 c0       mov  %rax,%cr0
In our system we are using bare-metal application to run on CPU Core and when executing rex.W mov %rax,%cr0 it will generate a fault in our case.
Can somebody explain what Intel Compiler is doing there, why Intel compiler is deviating from Intel's instruction manual?
Adolfo_S_Intel
Hello @NStoj​  I am consulting this case and will provide more information as soon as possible.
Adolfo_S_Intel
Hello @NStoj​  Are you using some sample code, or creating your own code? Are you using any flags on the compiler?
Adolfo Sanchez
NStoj
Hello @AdolfoS_Intel​
Thank you for the reply.
Code is used to enable SSE and AVX instruction set and we made trough Intel® 64 and IA-32 Architectures Software Developer’s Manual.
Flags which are passed to Intel compiler are:
-m64 -nostdinc -isystem -Ofast -march=broadwell -funroll-loops -Wall -Wstrict-prototypes -Wtype-limits -Wmissing-declarations -Wmissing-prototypes \
-fno-strict-aliasing -fomit-frame-pointer -fno-pic -fno-common -fno-stack-protector -ffreestanding -ffunction-sections \
-mno-red-zone
Nikola
NStoj
Hello @AdolfoS_Intel​,
Any news ?
Nikola
CarlosAM_INTEL
Hello, @NStoj​ :
Thanks for your reply.
We suggest you address this thread to the forum stated at the following website:
https://software.intel.com/en-us/Forum
@Mæcenas_INTEL​.
