Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
316 Discussions
Intel Embedded Xeon Processor - Using a single core 100% & not at all using other cores
Jerin_Paulose
Is there any issue, if I use a single core with 100% load for continuous 7 - 8 days, by not at all using other cores.
Eg. Consider 12 core Intel Xeon Embedded Processor D-1559. I will load Core 1 with 100% CPU load and won't use 11 cores. I may use Linux isolcpus method for this testing.
CarlosAM_INTEL
Hello, @Jerin_Paulose:
Intel CPUs are designed to run safely at 100% CPU utilization. However, you’ll want to avoid these situations whenever they cause perceptible slowness. You can confirm this information and more details on the following website:
 https://www.intel.com/content/www/us/en/gaming/resources/how-to-fix-high-cpu-usage.html
@CarlosAM_INTEL.
