Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
Intel® MBERE 1.2
KMANO3
Hello Team,
We are performing Signal Integrity simulation for DDR4. We referring the DDR4 model guide (545924-bdw-de-ddr4-si-model-rev0p95.zip). In that, they mentioned SISTAI MBER & MBERE 1.2 tool required for capturing Eye diagram. We couldnt able to find the SISTAI MBER & MBERE 1.2 installation file. Kindly share the installation file for the same.
Thanks in Advance,
CarlosAM_INTEL
Hello, @KMANO3​:
The Intel(R) Memory Bit Error Rate Executable [Intel(R) MBERE] document # 554422 is the tool that may help you. . This document can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/554422.htm
The RDC Account Support form is the channel to report or solve any inconvenience related to the cited site, also process your RDC account upgrade. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
@Mæcenas_INTEL​.
KMANO3
Hello Team,
Note FYI - We are using Broadwell -DE DDR4 Processor Model and for tr0 generation we are using HSPICE P-2019.06-SP1.1.
We have Installed Intel MBERE tool and associate MATLAB* Compiler Runtime (MCR) version 8.0 (R2012b).
While running Intel MBERE we are observed below mentioned error
MBERE_1.4
MBERE Run Completed
ans =
   0
Elapsed time is 0.858452 seconds.
read in data ended:
Reference to non-existent field 'isi_node'.
Error in read_all_tr0_data (line 142)
Error in new_rfda (line 561)
Error in run_extool (line 279)
Error in ex_tool2>run_case_Callback (line 1029)
Error in gui_mainfcn (line 96)
Error in ex_tool2 (line 42)
Error in @(hObject,eventdata)ex_tool2('run_case_Callback',hObject,eventdata,guidata(hObject))
Error while evaluating uicontrol Callback
Kindly provide your suggestion / feedback to resolve above mentioned errors.
CarlosAM_INTEL
Hello, @KMANO3​:
Thanks for your reply.
Based on your communication, could you please let us know if it is related to the following forum?
https://forums.intel.com/s/question/0D50P00004WxuaQSAR/ddr4-analysis-using-mbere-tool
We are waiting for your confirmation.
@Mæcenas_INTEL​.
