Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
317 Discussions
Xeon D1559 Power Sequence Issue
KMANO3
We are trying to bringup a new PCB, based on the Power sequence described in xeon-d-1500-datasheet-vol-3 R2.pdf
Judging by the SOC outputs, sequence is proceeding correctly nearly till the end (we see SOC de-asserting SLP_S4_N and SLP_S3_N, asserts DRAM_PWR_OK, activates clocks, ands read from SPI bus).
However for some reason PROCPWRGD_PCH and PLTRST_N never
de-asserts.
Can anyone advise how to root cause the reason why PROCPWRGD_PCH is not deasserted by the SOC? e.g. which signals to check?
CarlosAM_INTEL
Hello, @KMANO3​:
You should review the information stated in Table 3-35, and sections 3.4.1.11, 3.12.9.3, 3.12.11, 3.13.1.1, 3.21.3.8, 5.1.69, 7.7.5, 7.8.1.3, and 7.9.5; on pages 112, 113, 67, 107, 108, 111, 114, 167, 242, 313, 317, and 340 of the Intel(R) Xeon(R) Processor D-1500 Product Family External Design Specification [EDS] Volume 5 of 5: Integrated Platform Controller Hub document # 544044. This document can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/544044.htm
The RDC Account Support form is the channel to process your account update request. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
@Mæcenas_INTEL​.
