Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
310 Discussions
benchmarking QAT for HTTPs with wrk didn't work
rmole
Hello, here are some infomations:
1.QAT DEVICE INFO :
"qat_dev0 - type: dh895xcc, inst_id: 0, node_id: 0, bsf: 0000:03:00.0, #accel: 6 #engines: 12 state: up".
2. I've installed QAT async mode nginx accoding to https://github.com/intel/asynch_mode_nginx:
   ./configure \
       --prefix=$NGINX_INSTALL_DIR \
       --with-http_ssl_module \
       --add-dynamic-module=modules/nginx_qatzip_module \
       --add-dynamic-module=modules/nginx_qat_module/ \
       --with-cc-opt="-DNGX_SECURE_MEM -I$OPENSSL_LIB/include -I$QZ_ROOT/include -Wno-error=deprecated-declarations" \
       --with-ld-opt="-Wl,-rpath=$OPENSSL_LIB/lib -L$OPENSSL_LIB/lib -L$QZ_ROOT/src -lqatzip -lz -lssl"
make && make install
3.copy dh895xcc_dev0.conf from QAT_Engine Project to /etc, and there is SHIM section in it:
[SHIM]
NumberCyInstances = 1
NumberDcInstances = 0
NumProcesses = 32
LimitDevAccess = 0
# Crypto - User instance #0
Cy0Name = "UserCY0"
Cy0IsPolled = 2
# List of core affinities
Cy0CoreAffinity = 0
#No Data Compression here
4.vim NGINX_INSTALL_DIR/conf/nginx.conf:
   user root;
   worker_processes auto;
   load_module modules/ngx_ssl_engine_qat_module.so;
   events {
   ssl_engine {
       use_engine qat;
       default_algorithms ALL;
       qat_engine {
       qat_offload_mode async;
      qat_notify_mode poll;
           qat_poll_mode heuristic;
   http {
   ssl_asynch on;
   server {
      listen      4430 ssl; #asynch;
          server_name localhost;
      ssl_protocols      TLSv1.2;
      ssl_certificate     /root/ll/m.io.top/m.io.top.crt
      ssl_certificate_key /root/ll/m.io.top/m.io.top.key
      location /test {
         default_type application/json;
         return 200 '{"status":"success","result":"QAT"}';
      location / {
         root html;
         index index.html index.htm;
5.service qat start
6.NGINX_INSTALL_DIR/sbin/nginx
7.becnhmark from another server with wrk:
./wrk -t8 -c50 -d60s --latency -H "Connection: Close" https://m.io.top:4430/test
The 8 CPUs were always 90%~100% with or without QAT enabled.
Requests/sec with QAT is around 17000, wihtout QAT is 22000, really strange.
rmole
Plus the OS is Ubuntu 7.4.0-1ubuntu1~18.04.1. "uname -r" outputs 4.19.55​.
CarlosAM_INTEL
Hello, @rmole​:
Your Intel(R) QuickAssist Technology [QAT] consultations should be addressed as a reference to the channels listed at the following website:
https://01.org/community
@Mæcenas_INTEL​.
rmole
Hi, Mæcenas:
Thanks for your reply.
We've figured it out. The problem has been solved by adding ssl_session_tickets off; in nginx.conf.
gulue
