Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
307 Discussions
i wonder any data that expresses the difference between two cpu? ex)graph
영박000
CarlosAM_INTEL
Hello, @영박000​:
In order to help you, please research the Intel devices that you want to compare using their part numbers through the Intel (R) Product Specification portal that can be found at:
https://ark.intel.com
Once you made the search of each product, please enable the comparison of each one by clicking in the yellow highlighted bottom and when all the products have been selected click in the red highlighted bottom showed in the following screenshot:
Then you should obtain the comparison screen as the showed at the following image:
@Mæcenas_INTEL​.
