Ethernet Products
5719 Discussions
Работа сетевой карты Intel X520 SR2
DShir6
Здравствуйте! Приобрел сетевую карту Intel X520-SR2. Тестирую . Подключаю к PCI-express 3.0, подключаю sfp+ FTLX8571D3BCV-IT 850 нанометров. 1 SFP+ подключаю сдвоенным оптическим желтым кабелем к другому SFP+ на той же сетевой карте. Установил драйвер. Система Сетевую карту определила, то что устройство работает нормально - написала. А линк не поднялся. Сетевая карта способна работать сама с собой? подходят ли SFP+ под данную карту? Нужен ли какой то другой кабель для проверки?
Hello! Purchased a network card Intel X520-SR2. Test . Connect to PCI-express 3.0, connect sfp+ FTLX8571D3BCV-IT 850 nanometers. 1 SFP+ connect the dual optical yellow cable to another SFP+ on the same network card. Installed the driver. The system determined the Network card, then that the device works normally - wrote. Link didn't get up. Is the network card capable of working with itself? are SFP+ suitable for this card? Do I need some other cable to check?
AlfredoS_Intel
Hi DShir6,
Thank you for posting in Intel® Ethernet Communities.
To have a better understanding of your issue, please provide the following information.
a. If you are using a Windows Operating system, Please download and run our Intel® System Support Utility on this link, https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-. After running, kindly post the text file on your reply.
b. Please provide the brand and model of the cable used.
c. Have you tried using another cable for testing? Please refer to this link to view specifications required for the cable, https://www.intel.com/content/www/us/en/support/articles/000006946/network-and-i-o/ethernet-products.html
Alfred S
Intel® Customer Support
A Contingent Worker at Intel
AlfredoS_Intel
Hi DShir6,
Please let us know if you need more time to provide the information that we are asking.
Alfred S
AlfredoS_Intel
Hi Dshir6,
Since we have not heard back from you, we will close this inquiry now.
If you want to continue the thread, we suggest that you just create another topic on this forum, and we will gladly assist you.
Alfred S.
Intel Customer Support
