Ethernet Products
5703 Discussions
82574 is not recognized by PCIe bus ...
BAris
I have some problems regarding the WG82574 PCIe Gigabit Ethernet controller. I used it according to its sample schematics. However, it could not be recognized on PCIe bus. It should be added that the EEPROM connected to this IC have not programmed yet. However, I expected that the IC should be recognized without using the EEPROM. The schematic of this IC in my design is attached.
Babak
Hi Babak,
I'm currently checking your issue, will update this thread as soon as possible.
Vince
Hi Babak, we'd like to know if you have signed Non-Disclosure Agreement document (NDA) with Intel. Thanks.
Vince
BAris
Hi Vince,
Thank you very much for your reply.
Now, I can connect to the IC, and the chip was recognized by PCIe correctly.
The problem was related to the AC coupling capacitors on PCIe receiver lines. So, my problem was solved.
If I have another problem, I will ask you again...
Have a nice day,
NSøre
Hi Vince,
I was forwarded to the forum by your colleague Carlos, so I'll ask the question here as it is related to Babak's question (my colleague).
We have now the IC up and running, detected by the kernel. But now we need to program the NVM attached to the IC.
This is the ID from linux:
pci 0000:01:00.0: [8086:10d3] type 00 class 0x020000
And this is the output from the driver:
e1000e 0000:01:00.0: The NVM Checksum Is Not Valid
Currently the NVM (AT25320) is empty.
How do I manage to program the NVM from the board?
Do we need to sign a NDA in order to get a tool?
Thanks in advance.
Hi NilsDilau,
Thanks for writing back.
Yes, you will need to sign NDA in able to obtain the tool Kindly contact our https://kaveri.intel.com/ibl/help/support.htm Business Link support to request for the tool.
Sincerely,
Sandra
Hi NilsDilau,
We do not sell controllers to general public. You will need to go back to where you purchased or acquired the controller to get support for it.
Sincerely,
Sandra
