My question is I have 2 NIC Intel ETH Converged adapter X540-T2.
The firmware that is installed now booting PXE and I want that it booting
ISCSI.
So I must install a other firmware to do this.
I have also read the file on https://downloadmirror.intel.com/19186/eng/bootutil.txt https://downloadmirror.intel.com/19186/eng/bootutil.txt
I can't find the firmware relating to this NIC Card and also the
software to do this.
Can someone help me?
Hi Gluesppe,
Thank you for the post. The ISCSI is available in one single master FLB file, so what you need is to download the preboot.exe from https://downloadcenter.intel.com/download/19186/Intel-Ethernet-Connections-Boot-Utility-Preboot-Images-and-EFI-Drivers
Then extract the file and copy the bootutil.exe in the bootable drive to boot to DOS mode to execute the command.
BootUtil -BOOTENABLE=ISCSIPRIMARY
Please refer to this website for more information:
http://www.intel.com/content/www/us/en/support/network-and-i-o/000006727.html
wb
Hi Gluesppe,
Good day. I found you have similar query posted and is being supported by Sandy. Please update me if you still further assistance for this thread?
wb
