Ethernet Products
5655 Discussions
82599 with Enhanced Network Stack
akhmarov
Hello
We have strange issue with Enhanced Network Stack (ENS) on 82599 based card
The card is Fujitsu Eth Ctrl 2x10Gbit PCIe D2755 SFP+ [S26361-F3629-L502]
According to Broadcom's HCL it should support ENS with ixgben_ens driver version 1.7.1.0
https://compatibilityguide.broadcom.com/detail?program=io&productId=19666&persona=live&column=brandName&order=asc&vid=8086&did=10fb&svid=1734&maxSsid=11a9&productReleaseVersion=%5BESXi+7.0+U3%5D&activePage=1&activeDelta=20&redirectFrom=Eth%20Ctrl%202x10Gbit%20PCIe%20%20D2755%20SFP+
The config
[root@esxi:~] vmware -v
VMware ESXi 7.0.3 build-24585291
[root@esxi:~] esxcfg-nics -e
Name    Driver      ENS Capable   ENS Driven    INTR Capable  INTR Enabled  MAC Address       Description
vmnic0  ixgben      True          False         False         False         90:1b:0e:eb:7f:1f Intel(R) 82599 10 Gigabit Dual Port Network Connection
vmnic1  ixgben      True          False         False         False         90:1b:0e:eb:7f:20 Intel(R) 82599 10 Gigabit Dual Port Network Connection
[root@esxi:~] vmkload_mod -s ixgben_ens
vmkload_mod module information
 input file: /usr/lib/vmware/vmkmod/ixgben_ens
 Version: 1.7.1.0-1OEM.700.1.0.15843807
 Build Type: release
 License: Intel
 Required name-spaces:
  com.vmware.vmkapi#v2_6_0_0
 Parameters:
The issue
[root@esxi:~] zcat /var/log/boot.gz | grep ixgben_ens
2025-04-07T13:56:40.390Z cpu7:2097838)Loading module ixgben_ens ...
2025-04-07T13:56:40.391Z cpu7:2097838)Elf: 2119: module ixgben_ens has license ThirdParty
2025-04-07T13:56:40.396Z cpu7:2097838)ixgben_ens needs maximum 147456 bytes for shared heap
2025-04-07T13:56:40.396Z cpu7:2097838)Device: 211: Registered driver 'ixgben_ens' from 52
2025-04-07T13:56:40.396Z cpu7:2097838)Mod: 4821: Initialization of ixgben_ens succeeded with module ID 52.
2025-04-07T13:56:40.396Z cpu7:2097838)ixgben_ens loaded successfully.
2025-04-07T13:56:40.401Z cpu7:2097838)ixgben_ens: indrv_Attach:2241: Attaching ixgben_ens driver
2025-04-07T13:56:40.401Z cpu7:2097838)WARNING: ixgben_ens: indrv_Attach:2349: Device is not ENS uplink
2025-04-07T13:56:40.405Z cpu7:2097838)ixgben_ens: indrv_Attach:2241: Attaching ixgben_ens driver
2025-04-07T13:56:40.405Z cpu7:2097838)WARNING: ixgben_ens: indrv_Attach:2349: Device is not ENS uplink
So the driver could not initialize ENS:
Maybe there are special requirements like: disable SR-IOV in BIOS or something else to successfully enable ENS for 82599?
akhmarov
Seems I found the answer to my question:
Broadcom HCL says that 82599 card supports Enhanced Data Path - Poll Mode only. And ENS in general is a EDP Standard which requires Enhanced Data Path - Interrupt Mode feature. No ENS for 82599 cards
akhmarov
