Ethernet Products
5709 Discussions
Access to I210 EEUPDATE tool and flash images
b_barnabee
Dear All,
We have designed a custom board with an I210 Ethernet controller. It enumerates on the PCIe bus correctly, but the Linux driver shows it as unprogrammed.
We need to flash the onboard flash memory, and for it we would need access to the EEUPDATE tool and to the production images.
We have tried to apply for a DZP account (search on the forums suggested that this will be the way), but it was rejected almost immediately.
Can you please help us with this issue?
If we have to sign an NDA to apply for a DZP account it won't be a problem, we are happy to do that. In that case can you please guide us through the process?
Thank you very much in advance!
Barnabas
Fikri_Intel
Hi b_barnabee,
Thank you for reaching the Intel Community.
The tool requested (EEPROM or EEUpdate64e) can be found in the Intel Resource & Design Center (RDC) privileged account on the following website:
https://www.intel.com/content/www/us/en/resources-documentation/developer.html
Kindly note the documents/files require NDA access with a Developer Zone Premier account. For further details, please refer to the article:
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
Fikri
b_barnabee
Hi Fikri_Intel,
Thank you for the response!
I have contacted Intel Support to help with the NDA process, I got so far that our company's details were requested, but unfortunately there is radio silence since about 6 days.
Can you please tell me who I should ping regarding status update about our NDA process?
I hope that the process will take off and we will be able to request a Developer Zone Premier account with the NDA.
Barnabas
MACM
Hi b_barnabee
Greetings from Intel.
Hope you are doing well.
We would kindly suggest you wait until the concerned team responds regarding the NDA.
Ali
Fikri_Intel
Hi b_barnabee,
Good day!
Just wanted to follow up with you, kindly let us know if you have further concern.
Fikri
b_barnabee
Hi Fikri,
Unfortunately absolutely nothing has happened, Intel Support is continuing to be silent with no response.
We weren't able to take a single step towards the signed NDA and our DZP account which is starting to get frustrating.
Do you have any tips how we could escalate this process to at least go to the next step?
Thank you!
Barnabas
Sachinks
Hello b_barnabee,
Good day!
Thank you for your reply. We understand that it is taking a while for the NDA process and you are yet to get an update from the NDA team. Since the NDA approvals need verification, it takes some time for NDA to be issued.
Rest assured, you should receive an update from them at the earliest.
We request you to give it some more time. Thank you for your cooperation.
Thank you for using Intel products and services.
Sachin KS
intel.com/vroc
Fikri_Intel
Hello b_barnabee,
Good day to you.
Since you have engaged Intel Support, kindly share with us if there is a case number provided.
Fikri
b_barnabee
Hello Fikri,
Thank you for getting back to me!
The Case Number is 06422150.
Thanks in advance!
Barnabas
ManoranjanDas
Hi b_barnabee,
Greetings from Intel!
Thank you for sharing the case number. As per the case, we are currently coordinating with our internal team. Once we receive an update, we will promptly provide you with the status.
Manoranjan.
intel.com/vroc
Fikri_Intel
Hello b_barnabee,
Good day to you.
Upon checking the case: 06422150, our internal team is actively working on the NDA access. They will update you as soon as possible once the process is complete. We truly apologize for the delayed response.
Along with that, since case 06422150 is still open and pending an update, we will close this community case due to a similar issue.
Any additional updates will be shared under the web portal case (06422150).
Fikri
