I was able to download the program before, but after changing the value of register 0x24, I couldn't download the program anymore. Is there any way to reset everything or remedy it
Hello phsd,
Greetings from Intel!
Thank you for contacting Intel Support.
We understand that after incorrectly configuring the INVM mode register of the Intel i210, you are now unable to download to the register and are experiencing checksum failures.
To assist you further, kindly provide the following details:
- Product Information: Complete name/model of the Intel i210
- System Information: Details of the system where the adapter is installed
- Operating System: Version and type of OS in use
- Purchase Details: Was the adapter purchased separately or shipped as part of the system?
Please feel free to respond to this email at your earliest convenience.
Shankith K P
1. Model: i @ 122301GCP WGI210AT;
2. The system used is a PE system;
3. Purchased separately;
4. I want to configure it as fiber optic mode; Unable to communicate after successful configuration; Can you provide me with a txt document configured for fiber optic mode; I cannot configure BK in both 0x1536 mode and 0x157C mode。
5. The following is the txt document I configured. Can you help me modify it to fiber mode?
This is my schematic and optical drive module manual. How should I configure this i210?
Hello phsd,
We are following up to check if you were able to find the information we requested for.
Kindly revert with the details, so that we can continue assisting you in resolving this matter.
Thank you for using Intel products and services.
Shankith K P
Hello Phsd,
Thank you for sharing the details.
Based on the information provided, it appears that the NICs in your system are embedded, and we do not see any PCIe Ethernet Adapter listed. If this is confirmed, we regret to inform you that support for onboard NICs is limited. In such cases, we recommend reaching out to your system manufacturer for further assistance.
For more information, you may refer to the following article:
Please don’t hesitate to contact us if you need any further assistance.
Tejas
Hello Phsd,
Thank you for reaching out regarding the issues you're experiencing with Intel® Ethernet chips on your custom board. We’ve moved your concern to our dedicated Embedded Connectivity team for further assistance.
They will be in touch with you to provide the necessary support.
Shankith K P
