Ethernet Products
5568 Discussions
Altera MAX10 10M50 Rev C hardware config with linux image
I have an Altera MAX10 10M50 Rev C Development Kit that want to setup under Linux based on the instructions below :
https://rocketboards.org/foswiki/view/Documentation/AlteraMAX1010M50RevCDevelopmentKitLinuxSetup
Anybody knows more about the hardware configuration there? How fast is the CPU clocked? Is it using cache?
That information will be handy for benchmarking versus other targets.
Thanks and best regards,
Loic
Hi Loic,
It is kindly suggested that you just refer to the configuration of Quartus QSYSfor more details.
Then for your Q2, to this example in question, the NIOS CPU uses sys_pll_c2 clock (75MHz), you can adjust according to your practical configuration, i.e, if the on-chip memory is now in usage, theoretically speaking, 100MHz can be achieved;
Next for Q3, this example uses Cache, please check with the attached files. Viewing ath: NIOS CPU → NIOS II/f → Instruction/Data Caches.
BR,
Nikita
